Reply
ESR Follower
Follower
NVT200 - Installation issue - Intenet Timeout
Just purchased the NVT200 and going through the setup steps. The NVT finds my network, logs into the network using my credentials, and obtains an IP address.
Next step is "Verifying Internet Connection" -- I can't get past this step because the NVT states that the verification is TIMING OUT.
Isn't the network verified by the very fact that the NVT received an IP address?? How do I get past this silly error? Why is the network verification Timing Out? (can't be a weak signal - the router is 20 feet away!!)
I am using an Apple Airport Extreme router, that is on the 2nd floor loft (NVT on 1st floor), so there is minimal obstruction.
Thank you in advance...
ESR
Discussion Stats
  • 0 replies
  • 8788 views
  • 0 kudos
  • 1 in conversation
Top Contributors
User Kudos Count
1
