pmc3944's avatar
pmc3944
Follower
Jul 14, 2020
A7000 / Xfinity model TECHNICOLOR CGM4140COM
Received a new modem from comcast (TECHNICOLOR CGM4140COM).  My A7000 doesnt seem to want to connect.  The NetGear Genie shows connected, however my Windows Network Connections shows as "identifying" for a long time, the goes to "unknown network".  Even after I log into the wifi with this adapated and put the wifi password in.  Def checked the password multiple times.
*I can connected the same device to the same wifi using a different adapter
*The A7000 will connect to other networks (hot spot for example)
*I have updated all drivers / software associated
Any ideas?  Thanks!
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Looks like Windows does not like your "new" network
    Have you tried running the network troubleshooter in Windows?
    Maybe you need to tell Windows that you are on a "private network".
    • Network and Internet settings
    • Network Status
    • Change Connection Properties
    • Network Profile
    • Private
