Smoky23
Jun 23, 2023Follower
A8000
I just got a A8000 router . . . I think It's installed, but I don't know how to check to see if it's working or if I'm spinning my wheels. I also have a Star Link system, so do I really need this router?
1 Reply
There's no such thing. The A8000 is a USB wifi adapter. You use it to connect a PC to the wifi from a router.
I also have a Star Link system, so do I really need this router?Try asking Starlink what kit you need to work with its system.
