×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
GS605 Unmanaged Switch not working
CDRedstone
Follower
So, I have an Arris NVG599 router (i know, im sorry) and I was getting a red light from the WiFi router when I plugged the 5 port Desktop Gigabit Ethernet switch into an ethernet plug. I dont know if this happens on other routers too, but I was wondering if it is only compatible with Netgear routers.
Model: GS605v3|5 port Desktop gigabit ethenet switch
Message 1 of 3
Guru
Re: GS605 Unmanaged Switch not working
There shouldn't be any compatiblity issues.
But it could be a cable/port issue.
Have you tried different ports on the router/switch and a different cable?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 3
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Switches - NETGEAR Communities
Smart / Plus / Click Switches - NETGEAR Communities
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Discussion stats
  • 2 replies
  • 1324 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
