UnvoicedAlloy
Sep 14, 2023Follower
Nighthawk wireless AXE3000 wifi adapter A8000 registration key
I recently bought a wireless wifi adapter nighthawk AXE3000 and was having trouble trying to register it. I have no clue where to enter my registration key or where to enter it. I tried searching how and where but it seems this device is not very well known.
1 Reply
Are you
There is no "registration key" and you certainly do not need to enter anything to get the device to work.
NETGEAR Product Registration FAQ | Answer | NETGEAR Support
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
