sdafghjghgfh's avatar
sdafghjghgfh
Follower
Jul 05, 2024
Trouble switching to the A6100 wifi
I was just wondering if theres an easier way for me to connect to my other wifi. The one with the less bars is the netgear one, and rarely ever disconnects for me but it usually takes over like 20 times of connecting for it to finally switch from the default one. Switching from the wifi tab on my pc doesnt work either because they would both just say connected.
Thanks
  • michaelkenward's avatar
    michaelkenward
    That should be down to your Windows (?) PC.
    Your "other wifi" will have its own SSID.
    Windows 11 has this:
    It shows the WiFi sources near me. I then pick the one I want to connect to.
  • schumaku's avatar
    schumaku
    There are -two- downloads contained in the as of writing current A6100 downloads:
     https://kb.netgear.com/000059141/A6100-Software-Version-1-0-0-36
    Software Included
    A6100-V1.0.0.36.exe.zip
    A6100-V1.0.0.36_standalone.exe.zip
    On modern Windows 7, 10, and 11 (yeah) you don't have to run this long time obsolete Netgear application (once downloaded again, uninstall it from the Windows software list), and install the drivers only, why ever obfuscated as "standlone" by Netgear.
    Once recognized in Windows, you can configure and use it by standard Windows functions, no more Netgear junk application - a relict from the earlier Windows generations.
