- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
cambiare da 2.4 a 5 Ghz
- Mark as New
- Bookmark
- Subscribe
- Permalink
buon pomeriggio
ho un NETGEAR WNDA3100v2 N600 Wireless Dual Band USB Adapter
La versione v2 per mette lo switch da 2.5 a 5.
Se sì come devo fare?
Ho uno SKY wifi hub
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: cambiare da 2.4 a 5 Ghz
You have to set your router to display both bands. Then you simply select the 5ghz band
- Mark as New
- Bookmark
- Subscribe
- Permalink
for the quick response.
But where do I have to make the selection?
The router is automatically displaying bpth bands and other devices (like Apple TV) have been linked automatically
- Mark as New
- Bookmark
- Subscribe
- Permalink
within windows?
Or linux? Or macOS.
Whatever operating system you use, you select which band to connect with.
Unless the router using a single ssid function (same ssid for both bands). Then its more complicated.
