Orbi WiFi 7 RBE973
Reply
Buzzing noise on IP camera connected to GS305P
AmbassadorOne
Follower
I'm running a new Netgear GS305P to power a Reolink IP POE camera. Whenever the camera is touched by a hand or a few drops of water (waterproof camera) there is buzzing/static over the audio feed. I replaced the camera once already assuming it was faulty and the new camera buzzes as well so I am assuming it is the switch. My outlet is grounded and I am using shielded cabling. Is there known issue with this particular switch causing a feedback issue like this or does anyone have any suggestions as to what might be wrong?
Model: GS305P|5 Port Gigabit Ethernet Unmanaged Switch with 4-Port PoE
Message 1 of 3
JohnC_V
NETGEAR Moderator
Re: Buzzing noise on IP camera connected to GS305P
@AmbassadorOne,
Welcome to our community! 🙂
It seems that you are having issues with your POE camera that is connected to the GS305P. May I know if you tried to use another POE switch just to isolate? Does it still work fine if the camera buzzing its audio?
John
NETGEAR Community Team
Message 2 of 3
web-ster
I have this exact issue on a gs110tp 8 port. My switch is not grounded though as it is powered by an isolated power brick..
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1237 views
  • 1 kudo
  • 3 in conversation
Announcements
