Reply
Cable to daisy chain netgear unmanaged switches
herringc75
Follower
We need to expand our in home wired network. Currently we have a single unmanaged netgear ethernet switch (GS105). We need to run a cable from that switch upstairs (~30 feet away), where we'll put  another switch to allow two-four connections. We likely will get another GS105 switch.
Question: Will we need a crossover cable between the existing switch and the new (upstairs) switch, or will a patch cable do?
Model: GS105|5 Port Gigabit Ethernet Switch
Message 1 of 2
Guru
Re: Cable to daisy chain netgear unmanaged switches
A standard ethernet cable works fine. Nothing special needed.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1098 views
  • 0 kudos
  • 2 in conversation
Announcements
