Orbi WiFi 7 RBE973
Can't login from Prosafe 2.3.5 after 2.0.1.40 firmware update
cdmiller
Today I received a security alert from Netgear about older verions of Prosafe.  So, I went online to check out my version.  While I was on the latest version of Prosafe, I saw that I was not using the latest firmware (2.0.1.40).  I was using 2.0.1.26.  So, I updated the firmware.
Since doing so, I am not able to login using the Prosafe utility.  I get the message "Login Command is not supported by agent!".  I am able to login from Firefox using the switche's IP.
After quite some time, I've powered off the switch in hopes I could login.  But to no avail.
Has anyone else had this problem?  Any suggestions?
Thanks,
Chris.
Model: JGS524v2|ProSAFE 24-port Gigabit Rackmount Switch
Message 1 of 5
Accepted Solutions
XavierLL
NETGEAR Employee Retired
Re: Can't login from Prosafe 2.3.5 after 2.0.1.40 firmware update
HI cdmiller,
Could you let us know which switch model do you have ?
The latest ProSafe version that we have it's the 2.4.3 and you can download from :
https://kb.netgear.com/000037852/ProSAFE-Plus-Configuration-Utility-v2-4-3
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
Message 3 of 5
All Replies
militis
I am having the exact same experience. I can login when using Firefox but in Chrome there is no input box for the password field after updating the firmware to 2.0.1.40 from 26.
Model: JGS524v1|ProSAFE 24-port Gigabit Rackmount Switch
Message 2 of 5
XavierLL
HI cdmiller,
Hope it helps!
Xavier Lleixa
NETGEAR CBU PLM
Message 3 of 5
cdmiller
Upgrading to Prosafe 2.4.3 resolved this problem.  I should have tried that first.  I can no login successfully from the utility.  Thank you for your help.
Message 4 of 5
XavierLL
thanks cdmiller to let us know 🙂
Enjoy your Plus Switches!
Regards
Xavier Lleixa
NETGEAR CBU PLM
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 4886 views
  • 0 kudos
  • 3 in conversation
Announcements
