Reply
GS108 port mirroring, replacing hub
PerF
Are trying to replace an old hub between five computers with a ProSafe GS108T switch. The fifth computer works as a network monitor. The problem is if I use port mirroring in GS108T for the network monitor computer (its port is configured as "probe") I receive the mirrored packages but the monitor computer cannot participate in the network any more (e.g. send and receive packages using its own ip).
I know this is not standard behavour but the custom built monitor software also requires network connectivity. Are there any settings or other switches where this is possible?
Model: GS108|Gigabit Switches
Message 1 of 4
DaneA
NETGEAR Moderator
Re: GS108 port mirroring, replacing hub
Hi @PerF,
Welcome to the community! 🙂
In a GS108T switch, the port configured as destination port (probe) in Port Mirroring will no longer pass traffic.
DaneA
NETGEAR Community Team
Message 2 of 4
PerF
Thanks for a quick reply! This was the observed behaviour.
Can you recommend any other Netgears products where such a configuration with mirroring and still pass traffic while in use would be possible?
Message 3 of 4
jonathan_l
NETGEAR Expert
I think the purpose of port mirroring is analyze/debug/capture the packets copied from another switch port, the interface connects to mirrored port should not access the network.
For me, I would use two different interfaces on the PC, one for normal internet access, and one for connecting to mirror port for analyze/debug/capture (e.g. via usb-ethernet adapter)
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 4145 views
  • 2 kudos
  • 3 in conversation
Announcements
