Orbi WiFi 7 RBE973
Reply
GS108 to GS108T but only 100Mbps between them?
probedb
Tutor
Hi,
I have both a GS108 and a GS108T connected together.
The GS108 has two PCs connected, both connecting at 1Gbps.
The GS108T has 6 100Mbps devices (avr, blu-ray player etc) and a gigabit Asus router connected.
However the connection between the two switches is only showing 100Mbps?
Any thoughts on why this would be? There's only about 15m between the two switches so I don't understand why they won't connect at 1Gbps. Are there special ports on them for connecting between the two switches?
Many thanks,
Paul.
Message 1 of 5
Accepted Solutions
DaneA
NETGEAR Employee Retired
Re: GS108 to GS108T but only 100Mbps between them?
Hi probedb,
Thank you for your feedback.
Don't get embarass... its alright... we're humans Smiley Very Happy  I am glad that the cause was figured out and it is now working fine.  Smiley Happy
Cheers,
DaneA
Netgear Community Team
Message 4 of 5
All Replies
DaneA
Hi probedb,
Kindly answer the questions I have summarized below:
1. Is your GS108T a v1 or v2?  v stands for "version."
2. What is the current firmware version of your GS108T?
3. Are you using a CAT5e or CAT6 ethernet cable between the GS108T and GS108?
4. Have you tried using all of the ethernet ports of both GS108T and GS108 and still getting 100Mbps connection between the the two?
5. Have you tried to reboot both GS108T and GS108?  Are you still getting 100Mbps connection after rebooting the two switches?
6. Have you tried to reset the GS108T back to factory defaults and still  getting 100Mbps connection between the the two switches?
I will be looking forward to your response.
DaneA
Message 2 of 5
probedb
Tutor
How very embarassing...I thought I'd checked the cable, cut the ends off and recrimped them with new connectors...and it worked. Doh.
Message 3 of 5
DaneA
Hi probedb,
Cheers,
DaneA
Message 4 of 5
probedb
Tutor
Many thanks 🙂
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 7573 views
  • 1 kudo
  • 2 in conversation
Announcements
