Reply
GS308P PoE Switch - Slow Wifi
Andysubstanz
Hi,
I am using a Netgear GS308P PoE Switch in combination with a D-Link DAP-2660 AC1200 Dualband Access Point with PoE on the 2,4 GHz band. My download rate is very low (6 Mbit/s vs 100 Mbit/s available via LAN) and I am still searching for possible reasons. Has anyone else encountered a similar problem and found a solution?
Besides the AP I haven’t connected any additional device to the PoE-ports of the switch. The other LAN ports are also not used at the moment of the test.
Best regards
André
Model: GS308P|ProSafe 8 ports gigabit switch with 4 ports PoE
Message 1 of 3
schumaku
Guru
Re: GS308P PoE Switch - Slow Wifi
The weak point is always the wireless connection - very unlikely an Ethernet switch issue.
Lack of any details, the wireless client used for the test, ... hard to help. What numbers do you get on 5 GHz?
Message 2 of 3
Andysubstanz
Thanks a lot for your answer. Things got worse in the meantime. Therefore I am in contact with my internet provider. I will get back to you with more details in case things are not caused by my internet connection or router.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 654 views
  • 1 kudo
  • 2 in conversation
Announcements
