Orbi WiFi 7 RBE973
GS308v3 to Modem connection problem
Mikeyb0715
Initiate
Hey everyone and anyone,
Just recently bought a Gs308v3 switch to help with extending port availability during these crazy times. I connected into port 1 the cable from my router and in port 2 connected my MacBook. Everything works in regards to that, I have internet connectivity to the MacBook. I tried connecting into port 3 another MacBook and an iMac to port 4. Ports 3 through 8 don’t have internet connectivity.
Any suggestions as to why? I’d assume that it would be defective if I didn’t have any internet connectivity when connecting to any port but it seems like something might be off in regards to the other ports.
Any help is appreciated!
Message 1 of 4
Accepted Solutions
schumaku
Guru
Re: GS308v3 to Modem connection problem
Just wanted to check if it was the modem (where ISP assign only one IP typically - so other devices can't access the Internet). Easy to make a mistake wit that many devices and cables. Happy you figured out the connection mishap!
Message 4 of 4
All Replies
schumaku
Guru
What now - is that device before ... a modem or a router?
What IP address does that MacBook receive? An RFC1918 private address like 192.168.x.y, 172.2x.y.z, 10.a.b.c - or a public IP address (or again a CGN IP address 100.64.c.d)?
Message 2 of 4
Mikeyb0715
Initiate
Thanks for the reply, I was a dummy and connected it to a modem first when i should've been connecting to the router.
Message 3 of 4
schumaku
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1247 views
  • 2 kudos
  • 2 in conversation
Announcements
