Orbi WiFi 7 RBE973
Reply
JGS524 ECCN and CCATS
kenchen_aruba
Hi,
Can someone please provide the following information for JGS524? I need it to ship outside of the US.
US ECCN
CCATS
HTS Code
Does this Switch operate on Layer 3? If not, what layer does the switch operate on?
Does this Switch have/use MIMO technology?
Does this Switch use in ISP/TSP?
Does this Switch have/use SIMO technology?
Thanks
Ken @ Aruba HPE
Model: JGS524|24 Port Gigabit Switch
Message 1 of 8
schumaku
Guru
Re: JGS524 ECCN and CCATS
@YeZ please assist 8-)
Message 2 of 8
DaneA
NETGEAR Employee Retired
@kenchen_aruba,
Welcome to the community! 🙂
US ECCN
CCATS
HTS Code
About the US ECCN, CCATS and HTS Code, kindly access and read the link below:
US Customs Compliance
The JGS524 is a Layer 2 switch.
Both MIMO (Multiple-Input Multiple-Output) and SIMO (Single Input, Multiple Output) are for wireless communications and therefore NOT supported by the JGS524 switch.
If you need to extend your LAN, you will need the JGS524 to connect more devices hardwired like PC, network printer, etc.  Be reminded that the recommended setup would be: modem-router-JGS524.  You will need an ISP subscription so that you can have internet access.  The JGS524 does not support TSP.
The latest JGS524 switch model is the JGS524v2 (v = version).  To know more about its specifications, kindly check its data sheet here
DaneA
NETGEAR Community Team
Message 3 of 8
kenchen_aruba
Hi DaneA,
Thanks for the reply.
I looked at US Customs Compliance, I see several ECCNs listed, which one do I use for JGS524?
Also, I don't see HTS or CCATS mentioned.
Thanks
Ken
Message 4 of 8
schumaku
Guru
Model Number - Description - Line - ECCN # - Import HTS - Export Schedule - CCATS#
JGS524 - 24 port Gigabit Ethernet Switches - Switch - 5A991 - 8517.62.0050 - 8517.62.0050 - G044731
Message 5 of 8
kenchen_aruba
Hi Schumaku,
Thanks for the information!
Ken
Message 6 of 8
schumaku
Guru
Glad to help - be aware I'm neither Netgear nor an import/export crack - but this should be fine so you won't be prosecuted 8-)
Message 7 of 8
kenchen_aruba
Hi schumaku,
It will be fine, I just need the information for our Global Trade department will let me know if the information seems to not add up.
Again, thank you for the info!
Ken
Aruba HPE
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2141 views
  • 0 kudos
  • 3 in conversation
Announcements
