Reply
New Unmanaged High-Power Switches with PoE+ and PoE++ ports - Power and Simplicity
BretD
Admin
Introducing the highest PoE power on the market for Unmanaged switches with two new 16-Port and 24-port PoE+/PoE++ Unmanaged Switches, ideal for powerful PoE installations of all types with PoE budgets up to 480W, a compact size, plug-and-play installation, and reliable performance at affordable prices. Standardized to IEEE 802.3bt, these switches can also deliver up to 60W of power on part of their ports, allowing the connections of higher power required devices, such as Smart building lighting, Audio Speakers and 4K/8K Pan-Tilt-Zoom cameras.
Additional new unmanaged switching options with PoE+ are also available for your next deployment so be sure to browse the latest switch offerings.
Read the PoE++ Blog by Marynel R. and the Press Release for GS524UP Series or learn more about PoE technology.
Switch Series Features:
e635f0fc-cfbf-49b4-89e7-43498c134791[1].pngPLUG AND PLAY: Simple setup with no software or configuration needed
POWER-OVER-ETHERNET: PoE+ and PoE++ Options
COMPACT, FLEXIBLE FORM FACTOR:  Small case with internal power supply and whisper-quiet fans and Desktop and Rack-Mount
PoE AUTO-BALANCE: unique PoE technology automatically balances the PoE power based on the device needs independent of PoE class detected. These switches deliver the power the device needs, at the most granular level.
Limited LIFETIME WARRANTY: Next Business Day replacement and 24/7 chat with a NETGEAR expert
GS524UP PoE++ Switch
NETGEAR 24-port Gigabit Ethernet High-Power PoE+ Unmanaged Switch with 16 ports Ultra60 PoE++ and 8 ports PoE+ and an impressive 480W Power Budget. Ideal for powering and connecting wireless access points, 4K/8K PTZ IP Cameras, LED lights and IoT devices. Desktop or rackmount for flexible placement. Learn More
GS516UP PoE++ Switch
6c1cc1d3-82c0-4a7f-8ed2-2d6459e40b51[1].pngNETGEAR 16-port Gigabit Ethernet High-Power PoE+ Unmanaged Switch with 8 ports Ultra60 PoE++ and 8 ports PoE+ and a large 380W Power Budget. Ideal for powering and connecting wireless access points, 4K/8K PTZ IP Cameras, LED lights and IoT devices. Desktop or rackmount for flexible placement. Learn More
GS524PP PoE+ Switch
NETGEAR 24-port Gigabit Ethernet Unmanaged High-power PoE+ Switch with 300W Power Budget. Ideal for powering and connecting VoIP phones, wireless access points, 4K/8K IP Cameras and IoT devices. Desktop or rackmount for flexible placement. Learn More
GS516PP PoE+ Switch
NETGEAR 16-port Gigabit Ethernet Unmanaged High-power PoE+ Switch with 260W Power Budget. Ideal for powering and connecting VoIP phones, wireless access points, 4K/8K IP Cameras and IoT devices. Desktop or rackmount for flexible placement. Learn More
Please let us know what you think of these latest offerings in the comments below.
Please click KUDOS or REPLY If you found this helpful.
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 1726 views
  • 1 kudo
  • 1 in conversation
Announcements
