Orbi WiFi 7 RBE973
Reply
Not enough power?
pdjhh
Tutor
Not enough power?
Hi there.
I have one install with about 10 of these poe+ switches with cambium poe+ access points on most ports and all is good. I have another site with one of these switches and just 2 of the same access points connected and the APs were rebooting. I got cambium to take a look and they said the access points weren't getting anough power. I changed the switch but got the same issue. I had those APs running back at my desk on the same switch type and they were fine. I bought power injectors and the APs have been fine since but I can't understandf why they won't run on the switch. Is there any posibility that the source power isn't clean or something like that? I do have a couple of poe phones on the switch and they're fine.
Thanks.
Message 1 of 7
Guru
Re: Not enough power?
There's different power adapters for those models that allow different power levels. If you look at what power adapter is on the switch, it should tell you what power it puts out on the datasheet for that supply. That could be the difference.
What Cambium AP is it? It could be boarder line "just enough" power for short distances but with longer runs, have enough power loss it isn't stable.
Message 2 of 7
pdjhh
Tutor
Yeh I always use the same, big power supplies so it's not that.
Message 3 of 7
Guru
What cambium ap is it?
Message 4 of 7
pdjhh
Tutor
Cambium e425h. As I say I've got about 60 of these runing on the same switches at another venue with no hiccups at all.
Message 5 of 7
schumaku
Guru
@pdjhh wrote:
Cambium e425h.
Reads like a standard 802.3af or 802.3at powered device. Sufficient power to operate single  802.3af units (non-cascaded), permitting there is enough power available from the GS116PP.
Message 6 of 7
Guru
Yeah they should have enough power.
did you test them with a short cable run connected to that power supply?
Maybe there's an issue with the cabling l
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1543 views
  • 0 kudos
  • 3 in conversation
Announcements
