- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Replacement switch
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hopefully an easy question!
We're a small shop with two adjoining buildings. We currently have an FS108 switch in each - with the two switches linked by cable.
In one building we want to increase the number of network ports to say 12+.
Which switch in the current Netgear range would be most appropriate to work with an FS108??
Advice gratefully received. Ian
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Ian1976,
You're welcome! 🙂 Nice to know you've already ordered the GS116v2 switch.
NETGEAR Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Replacement switch
Hi Ian1976,
Welcome to the community!
I recommend you the GS116v2 switch. The GS116v2 is a 16-port unmanaged, desktop switch that is capable of 1000Mbps of ethernet connection. Its also backward compatible to the FS108 switch which only supports 10/100 Mbps of ethernet connection. Check these links below for more details:
I also recommend you the JGS516v2 and JGS524v2 switches. The JGS516v2 and JGS524v2 are 16-port and 24-port unmanaged, rackmount switches respectively that is also capable of 1000Mbps of ethernet connection. Its also backward compatible to the FS108 switch which only supports 10/100 Mbps of ethernet connection. Check these links below for more details:
JGS516v2 / JGS524v2 Data Sheet
For me, it would be best if you will replace the FS108 switches since it only supports 10/100 Mbps of ethernet connection with switches that is capable of 10/100/1000 Mbps of ethernet connection like the GS116v2, JGS516v2 or JGS524v2 since most networking devices supports Gigabit connection.
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply Dane. I've just ordered up the GS116v2 as indicated.
Cheers, Ian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Ian1976,
