Orbi WiFi 7 RBE973
Reply
Require multiple LOV for JGS524 series switches
Tallrocker
Follower
I require letters of volatility for the following unmanaged switches:
JGS524
JGS524E
JGS524F
JGS524v2
Thanks for the help.
Model: JGS524|24-port Gigabit Switch, JGS524F|ProSAFE 24-port Gigabit Switch with 2 SFP slots, JGS524v2|ProSAFE 24-port Gigabit Rackmount Switch
Message 1 of 2
Accepted Solutions
JohnC_V
NETGEAR Moderator
Re: Require multiple LOV for JGS524 series switches
Hi Tallrocker,
Here is the letter of volatility for the following unmanaged switches. The link will expire after 48 hour period and no password needed.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Message 2 of 2
All Replies
JohnC_V
NETGEAR Moderator
Hi Tallrocker,
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1308 views
  • 1 kudo
  • 2 in conversation
Announcements
