Reply
Switch to Switch redundancy
emullaraj
Hello comunity,
Iam struggling for a solution in this situation:
a) 2 Switches GS724T400TV4 ProSafe 24 Ports Gigabit Smart Switch one with firmware version 6.1.9 and the other 6.1.4.
b) 3 Servers Connected with 2 network cards on each; Switch 1 Vlan 110 (172.16.15.0/24) port 1,2,3 and Switch 2 (192.168.8.0/24) port 1,2,3 Vlan 111
c) Two different routers connected on each switch configured to comunicate with each vlan
Router 1 connected to Switch 1 at port 16.
Router 2 connected to Switch 2 at port 16.
I was wondering if : from port 1 of switch 1 to communicate with router 2 at switch 2 and the oposite from the router to the switch.
Can o port of the switch in this case example port 1 be part of two vlans at the same time?
 Is it possible to configure switch to switch redundancy ?
Model: GS724Tv4|ProSafe 24 ports Gigabit Smart switch
Message 1 of 4
jguerdat
Guru
Re: Switch to Switch redundancy
Wrong forum. This is for the Arlo cameras.
Message 2 of 4
JohnC_V
NETGEAR Moderator
Hi @emullaraj,
Welcome to our community! 🙂
Yes, It is possible to communicate these 2 VLANs even if they do have different WANs. You may try to apply these settings:
- Create VLAN routing on both switches. Go to Routing> VLAN > VLAN Routing Wizard. Take note that this only works per interface.
S1 - VLAN 100 - 192.168.100.1 /24 (for the connection of static routing)
Assign this to port 16 - U
S1 - VLAN 110 - 172.16.15.1 /24
Assign the devices that needs to be routed to the other VLAN.
S2 - VLAN 100 - 192.168.100.2 /24 (for the connection of static routing)
S2 - VLAN 111 - 192.168.8.1 /24
Then create a static route on both switches. Go to Routing > Route Configuration.
S1 - Destination Network Address : 192.168.8.0 / 24; Next Hop address: 192.168.100.2; Preference 1
S2 - Destination Network Address : 172.16.15.0  / 24; Next Hop address: 192.168.100.1; Preference 1
Please let me know if you do have question. I tried to replicate this and it did work.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Message 3 of 4
emullaraj
Hello @JohnC_V,
Thank you for your reply. I was stuck in VLAN routing for a while. I applied the config that you explained to me but didnt work at the begininng. Than i factory reset my switches and started from the begining the configuration that you explained to me and it work fine. Mabye i have done something wrong at the begining i dont know but important is that i solved it.
Thanks a lot for your help and your time.
Best regards.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1893 views
  • 0 kudos
  • 3 in conversation
Announcements
