Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
mode B support
dromedaris
Follower
mode B support
According to this posting - https://community.netgear.com/t5/Plus-and-Smart-Switches-Forum/Poe-Mode-B-possible-on-pair-45-78/td-..., the following is true:
> Today's standard compliant PoE switch PSE are able to power on Mode A or Mode B depending on the ability and need of the PD. It's not a user choice, thus nothing to enable.
The datasheet of the GS108P does not mention mode B specifically. I'm interested in using a mode b only PD  (two pair ethernet) with any standard (managed or unmanaged) switch that allows this.
Model: GS108P|ProSafe 8 ports gigabit switch with 4 ports PoE
Message 1 of 2
schumaku
Guru
Re: mode B support
The datasheet of the GS108P does neither mention mode A specifically, too.
Common agreement here is the that standards compliant PSE can negotiate Mode A and Mode B.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 340 views
  • 0 kudos
  • 2 in conversation
Announcements
