- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
105 switch and access point
I have an unmanaged 105 5-port Switch, I linked a Xclaim xi-2 AP to it, this leads to an unstable Wifi connection. When I take the switch out and connect the AP directly to the Router all is good. So the switch seems to be the problem. Any suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: 105 switch and access point
Hi @Stefan1010,
Welcome to the community!
Since the GS105 switch is an unmanaged switch, there are no settings that we could check because its just a pass-through switch. Kindly answer the questions below:
a. Are you using a GS105v5 (v = version)?
b. Was everything working fine before?
c. Have you tried to set a static IP address on the Xclaim xi-2 AP while its connected to the GS105 switch? If not yet, kindly try to set a static IP address on the Xclaim xi-2 AP then check if the same problem will occur?
DaneA
NETGEAR Community Team
