Orbi WiFi 7 RBE973
Reply
Can you control the switch using SNMP packets
Bazzababes
Follower
Hello, I would like to know if you can control and configue a switch (GS105) by sending SNMP packets. Failing that, what are packet protocols used in the communication of changes to the configuration of a switch? With this information, I can then start remotly configuring the switch, using scripts. (I acknoledge their are already .cfg files, but I want to use a script to send packets to the switch so that the switch changes configuration.)
Model: GS105|5 Port Gigabit Ethernet Switch
Message 1 of 2
Accepted Solutions
schumaku
Guru
Re: Can you control the switch using SNMP packets
The switch referenced (GS105) is a non-managed switch - no management, no config, no Web UI, no SNMP, ...
Message 2 of 2
All Replies
schumaku
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1255 views
  • 1 kudo
  • 2 in conversation
Announcements
