- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Does the GS108v4 support PoE?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you are looking for an 8-port Unmanaged Gigabit PoE switch, I suggest you either the GS108LP or GS108PP. Both of the GS108LP and GS108PP switches supports PoE/PoE+ on all 8 ports. The main difference between the two switches is that the GS108LP has a PoE Budget of 60W while the GS108PP has a PoE Budget of 123W.
For more information about the GS108LP and GS108PP switches, kindly check the data sheet here.
For a list of NETGEAR PoE switches that might fit your network requirements, check the links below:
NETGEAR Business Product Catalog Volume 19-1 - see page 23
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Does the GS108v4 support PoE?
No, the GS108v4 does not have PoE capability - Data Sheet GS105v5, GS108v4, GS116v2
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
Thanks for the prompt reply. Would you know of a decent model to accomodate me with Poe.
Regards Paul..
- Mark as New
- Bookmark
- Subscribe
- Permalink
DaneA
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks everyone for all your help.
Regards Paul...
