Orbi WiFi 7 RBE973
Flexible PoE Switch with Power Upgrade Options - Blog
Marynel
NETGEAR Expert
Do you need PoE In your Business?
What is PoE, you ask? Well, it stands for Power-Over-Ethernet, which means that just by using one Ethernet cable, you can supply both the network connectivity AND the power to run the PD (powered device). What this means for PoE-enabled devices like wireless access points, IP cameras, security door locks, etc, is that you won’t need to have a separate power supply and outlet nearby to install those devices; just run an Ethernet cable to them from a PoE switch, and you’re done!
Read more about PoE on the NETGEAR Blog:
Update Feb/5/2019:  The Extended range of upgradable power adapters for the Unmanaged PoE Switches - GS108LP GS108PP GS116LP and GS116PP are now available. Learn more about PoE from our Power over Ethernet Page.
To purchase the new PoE power adapters please click the model numbers below.
EPS90W
Compatible with
EPS130W
Compatible with
EPS200W
Compatible with
GS108LP
GS108LP
GS108PP
GS108PP
GS116LP
GS116LP
GS116LP
GS116PP
GS116PP
GS116PP
Message 1 of 2
Accepted Solutions
BretD
Admin
Re: Flexible Poe Switch with Power Upgrade Options - Blog
EPS90W
Compatible with
EPS130W
Compatible with
EPS200W
Compatible with
GS108LP
GS108LP
GS108PP
GS108PP
GS116LP
GS116LP
GS116LP
GS116PP
GS116PP
GS116PP
Message 2 of 2
All Replies
BretD
Admin
EPS90W
Compatible with
EPS130W
Compatible with
EPS200W
Compatible with
GS108LP
GS108LP
GS108PP
GS108PP
GS116LP
GS116LP
GS116LP
GS116PP
GS116PP
GS116PP
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 5334 views
  • 4 kudos
  • 2 in conversation
Announcements
