Orbi WiFi 7 RBE973
Reply
Is it possible to use 2 switches in parrallel
lewissurewise
Follower
We already have a GS324 24 port swtich and are looking to buy another to expand to 48, however are not sure if we should use 2 24 port switches in parrellel, or to just but a single 48 port switch which would be much more costly
Input much appreciated
Message 1 of 3
Accepted Solutions
DaneA
NETGEAR Employee Retired
Re: Is it possible to use 2 switches in parrallel
Hi lewissurewise,
Welcome to the community! 🙂
Its alright to connect another GS324 switch to your existing GS324 switch.  As far as I know, there is no limit on the number of NETGEAR unmanaged switches that can be daisy chained or be cascaded together.  However, be reminded that the best practice would be about 2-3 switches daisy chained or cascaded.  It is because each switch that you connect adds latency to the network.
DaneA
NETGEAR Community Team
Message 2 of 3
All Replies
DaneA
Hi lewissurewise,
DaneA
Message 2 of 3
DaneA
@lewissurewise,
I just want to follow-up on this.  Let us know if you have questions.
Otherwise, if ever your concern has been answered / resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2500 views
  • 1 kudo
  • 2 in conversation
Announcements
