Orbi WiFi 7 RBE973
Reply
JGS516 blinking lights
van_Velzen
My JGS516 Switch lights are blinking after I have installed ORBI Micro Router. It was working before
Situation:
1 I changed the Internet Modem from a Router to a Bridge (turned of Wifi and Router functions)
2 The Internet Modem/Bridge is connected to the Switch
3 The Orbi Router is connected to Switch and is working, I do have Wifi
4 The Laptop connected to Switch can't connect via cable, Windows message says:
Unknown Network
No Internet access
I'm a total network noob and probably did something wrong. I hope someone here can help me.
Thanks
Marco
Model: JGS516PE|ProSafe Plus 16 ports switch with PoE
Message 1 of 3
Accepted Solutions
schumaku
Guru
Re: JGS516 blinking lights
Suspect something wrong with the installation resp. the data path:
Internet <-> Modem/Bridge <-> Internet/WAN Port [Orbi Router] LAN Port <-> JGS516
Do not connect the switch direct to the modem/bridge and the LAN.
Message 2 of 3
All Replies
schumaku
Guru
Message 2 of 3
van_Velzen
Yes, that was the issue, a real noob error.
I did:
Internet - Modem/Bridge - Switch - Orbi Router
When it should have been:
Internet - Modem/Bridge - Orbi Router - Switch
I think that was in the first lesson on networks I ever had.
I wanted the router in the livingroom as it is quite esthetic, now its locked in the cabinet with the Modem and the switch.
Thanks for the reply.
Kind regards,
Marco
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1666 views
  • 1 kudo
  • 2 in conversation
Announcements
