Discussion stats
  • 2 replies
  • 645 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Trouble with GS116
I have a NETGEAR DOCSI 3.1 modem. Model CM1200. We purchased the Arris AX11000 router for its WIFI capability. The two work fine together, but when I plug my NETGEAR GS116 switch it does not work. Any suggestions?
Model: GS116|Gigabit Switches
Message 1 of 3
Accepted Solutions
Highlighted
Re: Trouble with GS116
Thank you for the response, we tried doing a complete reboot and it started working. Thank you for your time
Message 3 of 3
All Replies
Highlighted
Guru
The GS116 is a non-managed switch which should be working with easy for adding more ports to your Arris router or on one of it's satellites.
Tell us more on how/where this GS116 is connected to this set-up with the Netgear cable modem and the Aris WiFi system.
Message 2 of 3
Highlighted
Message 3 of 3
