× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Не работают snapshot
Артем
Добрый день!
Есть проблема с snapshot. Они не создаются для старых расшаренных папок. Сможете подсказать, почему? Snapshot-ы работают только для вновь созданных папок. Не хотелось бы их все пересоздавать.
Hello!
I will try explain in English.
I have troubles with snapshots. Snapshots not working with old share folders. They works only in new created shares. Why? Can you help with it?
Model: RN31400|ReadyNAS 300 Series 4- Bay (Diskless)
Message 1 of 11
Accepted Solutions
Артем
Re: Не работают snapshot
It works automaticly after I activate Audit button. I don't now why but it works. Thanks for help!
Message 10 of 11
All Replies
Guru
@Артем wrote:
Hello!
Do you mean that you can't create them?  Or something else?
Message 2 of 11
Артем
They are not created automatically.
Message 3 of 11
Guru
Do you use custom snapshots or smart snapshots?
Have you downloaded the log zip file?
Message 4 of 11
Артем
Both.
Could you tell me please how can I get log file?
Message 5 of 11
Guru
Download the log zip from the logs page in the admin web ui.
Message 6 of 11
Артем
Ok. Thanks. Here:
<redacted>
Message 7 of 11
Guru
Sorry - I should have said not to post the logs publicly.  I've redacted your link.
I am seeing a lot of messages like this:
Nov 20 06:11:01 fsbackupmp snapperd[3403]: snapshot check failed. not adding snapshot 14
But I am not seeing details on what exactly failed.  That particular message isn't always an error - I see it on my own system.  I use custom snapshots with the option to only make snapshots when the changes, and I believe that message also is logged when the share hasn't changed.
Smart Snapshots were pruned on 6 November, but not after that date.  The last automatic snapshots were created on 4 November.  It looks like you have plenty of free space in /data, so that shouldn't be an issue.
You might want to send a private message (PM) to one of the mods ( @JohnCM_S or @Marc_V ) with a link to your logs, and ask them to analyze them.  They might see something I missed.  You send a PM by clicking on the envelope icon in the upper right of the forum page.
You could try over-installing 6.10.2 manually, and see if that makes any difference.  I doubt it will, but it is safe and easy to do.  You could also try creating a new share with snapshots enabled, and see if those are created.
Message 8 of 11
Артем
Thanks for reply! Yes, when I create new share snapshots works properly.
I will send a private message (PM) to one of the mods ( @JohnCM_S or @Marc_V ). Thank you!
Message 9 of 11
Артем
Message 10 of 11
Guru
I don't why either (auditing is off on my system, and snapshots work ok).  But I'm glad it is working for you now.
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 1345 views
  • 0 kudos
  • 2 in conversation
Announcements
