Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-10-13
03:20 AM
2009-10-13
03:20 AM
In previous ReadyDLNA releases you guys implemented folder.jpg (or Folder.jpg) to be the same as cover.jpg so it would show as an album art for a folder (for example of video files).
At the moment cover.jpg works, but folder.jpg does not work anymore.
One advantage of having folder.jpg over cover.jpg is that Windows would apply folder.jpg to the folder as folder icon.
It is not a big deal though...
Message 1 of 13
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-10-13
11:26 AM
2009-10-13
11:26 AM
Re: [0.16pre4] album art for folder as folder.jpg
At the moment, you would most likely need SSH to modify the configuration file, and change the order of the filenames.
$ cat /etc/minidlna.conf
# port for HTTP (descriptions and SOAP) traffic
port=8200
# set this to the directory you want scanned.
# * if have multiple directories, you can have multiple media_dir= lines
# * if you want to restrict a media_dir to a specific content type, you
# can prepend the type, followed by a comma, to the directory:
# + "A" for audio (eg. media_dir=A,/home/jmaggard/Music)
# + "V" for video (eg. media_dir=V,/home/jmaggard/Videos)
# + "P" for images (eg. media_dir=P,/home/jmaggard/Pictures)
media_dir=/c/media
# set this if you want to customize the name that shows up on your clients
#friendly_name=My DLNA Server
# this should be a list of file names to check for when searching for album art
# note: names should be delimited with a forward slash ("/")
album_art_names=Cover.jpg/cover.jpg/AlbumArtSmall.jpg/albumartsmall.jpg/AlbumArt.jpg/albumart.jpg/Album.jpg/album.jpg/Folder.jpg/folder.jpg/Thumb.jpg/thumb.jpg
# set this to no to disable inotify monitoring to automatically discover new files
# note: the default is yes
inotify=yes
# set this to yes to enable support for streaming .jpg and .mp3 files to a TiVo supporting HMO
enable_tivo=no
# default presentation url is http address on port 80
#presentation_url=http://www.mylan/index.php
# notify interval in seconds. default is 30 seconds.
notify_interval=900
# serial and model number the daemon will report to clients
# in its XML description
serial=12345678
model_number=1
Message 2 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-10-13
05:08 PM
2009-10-13
05:08 PM
Maybe I'm posting in the wrong thread but I too can not get my XBOX 360 to display folder art for my video files. I have a movie in a folder and within that folder I have placed a file named "Cover.jpg", yet my XBOX 360 does not show it as folder art. Am I doing something wrong here?
Message 3 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-10-14
06:25 PM
2009-10-14
06:25 PM
The 360 isn't UPnP-A/V or DLNA compliant. The are "Windows Media Connect" compliant, and thus only Windows knows the special way to send it cover art AFAIK. PS3 and other devices will show video cover art though.
Message 4 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-10-14
06:28 PM
2009-10-14
06:28 PM
alenas wrote: At the moment cover.jpg works, but folder.jpg does not work anymore.
It still works for me. Do you have any other jpg's in the folder?
Message 5 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-10-14
06:58 PM
2009-10-14
06:58 PM
Skywalker, thanks for the reply but I'm not even sure what you mean. Does the ReadyNAS Duo currently show coverart for video folders or not? Is there something I'm doing wrong???
Message 6 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-10-15
03:49 PM
2009-10-15
03:49 PM
The Duo supports and advertises video cover art properly following the DLNA and UPnP-A/V spec. It's up to the client (in your case the 360) to request the image data and display it, and unforuntately the 360 will not do that. You're not doing anything wrong; the 360 just does not support it.
Message 7 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2009-10-18
03:10 AM
2009-10-18
03:10 AM
I did not have any other jpg's in the folder. I changed the config file and moved folder.jpg to the beggining of the line and then it worked.
Message 8 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2010-12-29
05:37 PM
2010-12-29
05:37 PM
Thanks to alenas for the above information. folder.jpg wouldn't display on my PS3 until I moved it to the beginning of the album_art_names list and restarted / re-scanned. My media looks much better now.
Message 9 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-13
06:46 AM
2011-07-13
06:46 AM
zipper wrote: Thanks to alenas for the above information. folder.jpg wouldn't display on my PS3 until I moved it to the beginning of the album_art_names list and restarted / re-scanned. My media looks much better now.
Hi
So just so I am reading this right.....artwork for the movie will now show up on the xbox 360 but you need to have e.g.
/Stars Wars/Star Wars.avi
/Star Wars.jpg
that right?
Message 10 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-13
12:00 PM
2011-07-13
12:00 PM
No, the 360 unfortunately doesn't support artwork in the standard way.
Message 11 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-19
03:48 AM
2011-07-19
03:48 AM
Skywalker wrote: No, the 360 unfortunately doesn't support artwork in the standard way.
Thanks for clearing it up.
Message 12 of 13
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-07-26
03:03 AM
2011-07-26
03:03 AM
tht's a real pity
http://mosh.ph/45165/beating-poor-cell-phone-signal-mobile-phone-signal-booster
http://shyandroid.com/2014/06/install-mobile-phone-signal-booster-house/
Message 13 of 13
