× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
0x80070035 fault after upgrade 6.5
Allard72
After upgrade to 6.5 of My readynas Duo v2, No access to any NAS folders
Access via Readycloud or connecting admin via IP is no problem.
Directly from computers with Windows 7 and 10 or my Home cinema set is not possible.
I get fault  0x80070035
Who can help me?
Model: ReadyNASRND2110v2|ReadyNAS Duo v2
Message 1 of 30
Guru
Re: 0x80070035 fault after upgrade 6.5
If you look at the share settings, is SMB enabled?
Also, can you confirm your model?  The duo v2 doesn't run OS 6.x firmware.
Message 2 of 30
Allard72
That's strange... The model has done a update by itself. today to 6.5.1. Model is RN10200
SMB is on
Anonymous is on at SMB
Workgroup on PC's and NAS are the same.
Connection is WIFI by the Netgear R7000 router
Message 3 of 30
Guru
@Allard72 wrote:
...Model is RN10200
Which is very different from a duo v2.
Did the update to 6.5.1 resolve the problem?
Message 4 of 30
Allard72
No, still the same problem. I have it on a win7 and win10 computer.
Tried also 6.4. Same problem
Have also put SMB on 2.1, instead of 3.0
Connecting by cloud, no problem
Connecting via Raidar - explorer, no error
Message 5 of 30
BrianL2
NETGEAR Employee Retired
Hi Allard72,
Welcome to the community!
Can you check if ReadyCLOUD is enabled? If yes, tell us if there is a similar e-mail address used by Cloud and one of  the local users registered in your ReadyNAS.
Kind regards,
BrianL
NETGEAR Community Team
Message 6 of 30
naki
I also have the same trouble.
0x80070035
Model: RN102|ReadyNAS 100 Series
Message 7 of 30
Guru
Raidar's browse function just opens up explorer with \\nasipaddress
If you enter \\nasipaddress directly into file explorer's address bar you should see the same thing.
If you do, then perhaps your problem is related to windows credentials.  Try deleting all credentials using the nasname, and re-entering one with the credentials you want to use.
Message 8 of 30
Hi all,
i have the same issue.
i believe the issue come from the OS used:
Windows 10 - cannot see on SMB normally, i see the server in the net but when click give 80070035 error, then open readyclud app and through it by clicking on the folder i access on it and in the net appear the ip address of the server ( try to type the ip by smb but not found before open the readycloud app)
anyway i can acess only on the folder of my remote account, no admin. to see all i must to use the admin page.
ubuntu 16.04 open the net and found only SMB server, acess using admin credential but i can see only the folder aloowed by remote account - no home folders also the remote account folder.
Android usinf FX Explorer - i can see all!!, home folder also.
Hope to be useful.
Model: RN10400|ReadyNAS 100 Series 4- Bay (Diskless)
Message 9 of 30
MikeFH
Look like a common isssue, not great!
Is this the same issue you all have ? - https://community.netgear.com/t5/Using-your-ReadyNAS/cannot-enable-any-readynas-services-in-netgear-...
Any idea how to fix it?
Thanks
Mike
Message 10 of 30
Allard72
That is a different Issue.
I installed Windows 7 on an other computer and it works fine
Seems to be a Windows 10 - Upgrade 6.5 problem.
Also installed new certificate and credential changed. Nothing works..
Can not reach the NAS-Files by using Raidar..... Installation screen using NASIP is no problem.
Ping is also ok
Set also SMB in Regedit open for guests
https://techjourney.net/cannot-connect-to-cifs-smb-samba-network-shares-shared-folders-in-windows-10...
any new ideas??.
Message 11 of 30
Guru
Your issue is a discovery problem (the PC apparently doesn't see the advertisement for NAS-GRAAF).
Check that the Windows PC is in the same workgroup as the NAS.  One workaround is to access the NAS using its IP address.
Message 12 of 30
realmcom
I am having the same issues as the OP.  Cannot access with IP either.  In fact I might post my own thread.
Message 13 of 30
Bdxdev
Same problem here guys, please help!!!!!!
Message 14 of 30
Guru
I suggest you start your own thread, perhaps with some screenshots showing more exactly what you are doing.
Also provide your NAS model and the firmware installed (6.5.1???).
Message 15 of 30
Bdxdev
Same problem and same screenshot like this thread.
Ready Nas 104 - No problem on OSX, no way to access from explorer in windows 10, i can login only in webadmin panel
Firewall Disabled, same workgroup, i'm going to be crazy 😮
Message 16 of 30
Guru
So what happens on the windows pc if you open CMD and enter
net use * /delete
net use t: \\nasipaddress\data /user:admin nasadminpassword
If the first command asks for confirmation, let it proceed.
For the second, fill in the reall ip address and the real NAS admin password.  It's very easy to mistype (slash direction and spaces both matter).
If it works, the NAS data volume will be mounted on the PC as drive T.
Message 17 of 30
Bdxdev
System said:
System error 86
Wrong Password!
I've typed the same admin panel password.
Message 18 of 30
BrianL2
Hi Bdxdev,
After executing the command posted by StephenB, kindly add the administrator page admin credential in your PCs Credential Manager -> Windows Credentials.
Hope this helps!
Kind regards,
BrianL
Message 19 of 30
Bdxdev
Credential Added but same error. No way 😞
Message 20 of 30
BrianL2
Hi Bdxdev,
Okay. Are you using ReadyCLOUD? If you are, can you confirm if your ReadyCLOUD accounts are also being used as e-mail addresses of your local ReadyNAS users (Accounts->Users)?
Kind regards,
BrianL
Message 21 of 30
Bdxdev
yes is the same, I've tried to change on readycloud but I have an Error!
Message 22 of 30
Guru
@Bdxdev wrote:
System said:
System error 86
Wrong Password!
Maybe double-check the typing.  net use is very fussy about syntax.
Also, is the NAS volumename the default "data" or is it something else?
Message 23 of 30
Bdxdev
where i can find the name of the volume data?
Message 24 of 30
Guru
You highlighted one of your volume names-  DISC01
The volumes tab is easier - the name is shown under the pie chart.
Message 25 of 30
Top Contributors
Discussion stats
  • 29 replies
  • 5271 views
  • 2 kudos
  • 9 in conversation
Announcements
