- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
3200 to 3200 Rsync Backup Fails
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have two 3200s (4.2.21) that were using rsync to backup volume c from one to the other successfully. Recently it stopped working. I've tried recreating the job but it still fails. When ran manually it shows the job starting but after refreshing the page it has stopped. I check the logs after each try and it always says "No backup log exists for this job".
I have SSH access in to the 3200 running the backup and tried looking in /var/log/frontview/backup for any logs but nothing is there. I'm not even sure this is where I should be looking for clues.
Any thoughts/advice is greatly appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 3200 to 3200 Rsync Backup Fails
@mdgm wrote:# df -h # df -i
NAS3200A:~# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 982M 2.9G 26% /
tmpfs 16K 0 16K 0% /USB
/dev/c/c 3.6T 1.1T 2.5T 30% /c
tmpfs 50M 0 50M 0% /var/replicate/shm
NAS3200A:~# df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
/dev/md0 65536 44983 20553 69% /
tmpfs 506381 1 506380 1% /USB
/dev/c/c 59113472 1035077 58078395 2% /c
tmpfs 506381 7 506374 1% /var/replicate/shm
Thanks for the quick replies and I hope this helps!
- Mark as New
- Bookmark
- Subscribe
- Permalink
4.2.21 is very old firmware and might have some compatibility issues with your web browser.
Could you update to 4.2.28 and try again?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the suggestion. Unfortunately right now the NAS is in production and pretty busy so I might have to wait a bit before I can update it. But if I can't figure out anything in the meantime then your suggestion is definitely the way to go. Thanks again!
