× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Reply
324 cpu architecture error - not booting.
Petroc
anyone encountered this error cpu_srchitecture+10? is my mas bricked?
Message 1 of 4
Guru
Re: 324 cpu architecture error - not booting.
Try powering down, removing the disks (labeling them by slot), and powering up diskless.
Does the NAS display show a no disks detected message?  If it does, the NAS is probably not bricked (and the error is disk-related).
Message 2 of 4
Petroc
Thank you @Tehen, knowing I had back ups of my shares a bit the bullet and turned the unit off at the plug as luck would have it  it rebooted and resynced without error and has been running without issue since it apparently no data loss if it happens again, I will take your advice. And only had this error message about the CPU architecture. Strangely, there is nothing in the logs either.
Message 3 of 4
Guru
I believe the error was a crash at that location during bootup.  That would explain the lack of logging.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 452 views
  • 0 kudos
  • 2 in conversation
Announcements
