× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
6.1.9 roll back to 6.1.8 possible?
fabNAS
Hi - It's couple of months that I have ReadyNas312 and the main reasons i bought it were the possibility to install Plex and Amule, they both worked fine until the firmware upgraded to the version 6.1.9. Now I get some initialization error 22002010000 when launching amule.
Netgear support suggest to contact the app author, which is easier to say than do, and also state that there is no way to downgrade to 6.1.8 from 6.1.9.
I guess I could also return the system to its factory default settings but I would prefer to avoid the hassle with the data.
Any suggestion?
Aprreciated
Message 1 of 5
mdgm-ntgr
NETGEAR Employee Retired
Re: 6.1.9 roll back to 6.1.8 possible?
Have you tried installing the amule add-on over the top of itself via the upload button on the Dashboard?
Message 2 of 5
fabNAS
Hi, thanks for your help.
My knowledge of NAS and in particular of my ReadyNas is almost null, the only thing I've done is remove it from APPS section, deleted the amule folder and re-install it from the APPS section. And it did not work.
I see the Upload button but I guess that means i need first to download in my pc the amule file which i don't know where to find them.
Message 3 of 5
mdgm-ntgr
Does Plex still work fine?
Message 4 of 5
fabNAS
Plex is fine yes
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1491 views
  • 0 kudos
  • 2 in conversation
Announcements
