× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
^6.6.1 Beta 4 Disks spinning down or up
JanHussaarts2
Apprentice
I've installed the lates beta and see the disks going to sleep and waking up regardless of the settings.
Furthermore in the settings in the UI under Disk Spin Down, I can only select of deselect disk spin down.
When deselected or selected there is no change in behaviour.
Model: ReadyNAS-Ultra 6|ReadyNAS-Ultra 6
Message 1 of 10
Accepted Solutions
JanHussaarts2
Apprentice
Re: ^6.6.1 Beta 4 Disks spinning down or up
Installing the official 6.6.1 release seems to have solved the problem.
Message 9 of 10
All Replies
Guru
What model ReadyNAS are you seeing this on?
Message 2 of 10
JanHussaarts2
Apprentice
On my legacy ultra 6
Model: RNDU6320 |READYNAS ULTRA 6 |EOL
Message 3 of 10
mdgm-ntgr
NETGEAR Employee Retired
Which services are you running?
Which apps are you running?
Which firmware did you update to 6.6.1 Beta 4 from?
Message 4 of 10
JanHussaarts2
Apprentice
6.6.0 Beta 1, patched by Skywalker because of problems with the fans.
I decided to install the latest beta because after a restart the 6.6.0 version did not see the volumes.
Only after a second or third restart it recognised them and took some time to scan the volumes.
I'm running Owncloud with MySQL.
The difference with before is that I've attached another UPS (APC) and configured the shutdown at 50%.
Message 5 of 10
mdgm-ntgr
Can you send in a fresh set of logs (see the Sending Logs link in my sig)?
Message 6 of 10
FramerV
Hi JanHussaarts2,
Just would like to do a follow-up. We would like to request for your system logs.
How do I send all logs to ReadyNAS Community moderators?
Message 7 of 10
JanHussaarts2
Apprentice
I have send the logs.
Message 8 of 10
JanHussaarts2
Apprentice
Message 9 of 10
FramerV
Hi JanHussaarts2,
Thank you so much for updating us and I am glad that the new firmware resolved the issue.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 2905 views
  • 0 kudos
  • 4 in conversation
Announcements
