- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
626x used as readydr destination deleted all snapshots
- Mark as New
- Bookmark
- Subscribe
- Permalink
Primary machine shows 3 years (59 snapshots). I noticed as the machine went from 50% utilized (12TB of 27TB).
I have lots from a few days before and all looks normal (looked in snapper) and then it looks like pruning started happening. Now show about 4TB of data.
Was manually starting ReadyDR for each share (one at a time and wait to complete) on the primary machine, also running 6.9.4. Logged into 626(backup destination) and noted drastic drop in total stored volume.
Verified that the root file system on both machines is normal (no file system over 25% full)
No additional apps installed except SSH.
Primary machine has 5.8TB free of 20TB.
Backup machine is normally off, only turned on for backups.
Any thoughts?
Setting up for another full backup of primary machine to external disk, not overwriting prior backups just in case there is a file system issue on the primary.
Thank you in advance for any recommendations
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 626x used as readydr destination deleted all snapshots
Appears the "complete" ReadyDR shares on the destination are the ones I had completed earlier in the day. The "empty" ones are the ones yet to go.
I did get the following message on the last ReadyDR backup(source machine): ReadyDR: ReadyDR job failure: Protocol error [share name]
A volume scrub was running on the source machine
Also note that after a reboot I get the following error on each ReadyDR on the source machine: ReadyDR: ReadyDR job failure: Operation not permitted [Share Name]
This happens immediately (and has for as long as I have been using ReadyDR) and I restart, all is well at that point. I thought I localized that first fail to key exchange issues...
I have always had the ReadyDR jobs disabled and initiate them with the "gear", they are labeled as "instant" backups (not periodic)
Source machine data looks healthy at this point.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I believe there is an un-diagnosed bug in 6.10.2 where "smart" snapshot management on a ReadyDR target share will inappropriately delete some or all of the snapshots (thereby rendering the backup useless).
My expereience was that (the only) two snapshots on the target, which were taken at hours other than midnight, were deleted under the 48-hour rule... Not so smart after all...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am running 6.9.4 on both machines at the moment. I wonder if the bug is in that version.
If I turn smart snapshots off on the destination readynas i assume it would not delete snapshots at all.
On the other hand it would have random additional snapshots from the source from whenever it ran (ie hourly, daily, weekly)...
Interesting that it ran fine until last week and then decided to prune all of the snapshots... it in fact deleted ALL of them on the backup server, most recent first it appeared... or at least when I looked there were only a few of the ones from 2016 left at that point.
If I kick off the ReadyDR job on the source it does rebuild with all of the old snapshots ending up on the backup. Just trying to understand why it did it and how to avoid in the future... would be sad for this to happen when the backups were critical!
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is possible that the file system reached the 95% full threshold?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Indeed. In my case I had another backup of the data, but I have now turned off smart snapshot pruning on all my ReadyDR shares....
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't use ReadyDR, but have done that for all my shares anyway. Custom snapshots give you control over retention for each share - which prevents the snapshots from eventually taking over all the space. I combine that with "only take snapshots when changes".
- Mark as New
- Bookmark
- Subscribe
- Permalink
I guess I will have to reevaluate my backup methodology going forward. Perhaps I will go to having rsync copies on the backup machine having their own snapshots in addition to the readydr shares.
If I turn off smart snapshots on the readydr volumes on the backup machine I assume I can manually delete intermediate readydr snapshots (ie the excess hourly, daily, and weekly snapshots) without impacting the stability of the readydr snapshots on the backup machine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
--Turn off smart snapshots on all destination ReadyDR shares.
--Set time based snapshot management, tried 600 months (50 years) which the interface converted to 4161 days (11.4 years)
--Turned off access to snapshots on destination 626x readynas (results in not being able to see snapshots even in interface unless turned back on)
--Disable network access completely on ReadyDR shares
Will verify if run readydr backup and then enable snapshot access that the data is there.
Will also clone a snapshot to the local backup machine and make sure that works as expected....
Thoughts on other things to do on a locked down backup machine?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well (FWIW and IMHO, etc.), that may be overkill.
The only problem I've experienced was with the "smart" snapshot management - having reverted to "custom" and set a long retention period (3 years) or large number of snapshots (128) I've had no further issues.
Snapshots are always read-only anyway, so I can't see what disabling snapshot access would gain. The only options you have from them (and therefore ReadyDR backups) is to extract/restore individual file(s) to another location or clone the entire share (space permitting).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Though I don't use ReadyDR, I agree it sounds like overkill. Eliminating snapshot pruning should have been enough, since snapshots can't be deleted over the network unless you are logged into the NAS with ssh and using the command line interface.
