Orbi WiFi 7 RBE973
Reply
A couple of questions on readyNAS NV+
thecitycup
Hi Guys,
I am not sure if it is permitted to put forward the following questions, if not, please kindly let me know.
a. The system will do re-sync after every manual reboot. How to configure to disable such operation, please?
b. Can it support Raid 10 in ReadyNAS NV + with RAIDiator 4.1.10, please?
c. I also buy one UPS for it, but not find a suitable buyer. Can you please give me some advice?
Thank in advance
Frank
Message 1 of 3
Guru
Re: A couple of questions on readyNAS NV+
Normally it will only do a file check if there was a clean shutdown. If it is resyncing, there should be information in the logs which indicate the reason.
RAID-10 is available on 6-bay or greater ReadyNAS only. So it would not be available on an NV+
I use a CyberPower CP1350AVRLCD with my NV+ and Duo, it has worked well for me. APC is another brand that many people buy.
Message 2 of 3
thecitycup
Cool! Thanks a lot!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1129 views
  • 0 kudos
  • 2 in conversation
Announcements
