- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AFP access not visible for all shares (Mac)
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an Ultra 4 model that I recently upgraded to OS 6. I am in the process of moving the data from my backup to the ReadyNAS but am having some difficulty with AFP access. In the Admin page via the browser, in the Shares section, I see the following:
Documents
Home Folders
Media
I deleted some of the default shares like Pictures and Videos, as I prefer to keep them in the Media share.
In the Mac Finder window, when I click on ReadyNAS (AFP) in the 'Shared' section in the Finder sidebar, the only share that appears is the Documents share. I am trying to access the Media share, but I can only see it if I select ReadyNAS (SMB) in the Finder sidebar.
When I look at the Media share settings via the browser, it shows that AFP access is on and the rest of the settings mirror those of the Documents share.
With OS 4, when I selected ReadyNAS (AFP) in the Mac Finder sidebar, all the shares appeared.
Was there a change with OS 6 or is there something else I am doing wrong?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
You are connected as a guest to AFP and have guest access turned off for the Media share. You either need to enable guest access for the share or login as a user to AFP.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AFP access not visible for all shares (Mac)
There are two levels of controls for shares.
The global under services.
Then each share has setting for control. Go to the shares tab and the left click on the share you want to change. Select setting.
Then goto the service that you want to configure. Turn it on and set any setting that are necessary.
That should have you working.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your response. I have checked the settings you mentioned and they are set the exact same as each other but only the Documents share is the one that shows up as an AFP share. I am wondering if I need to reset the NAS again. The default shares all showed up as AFP shares but any new shares I add, do not.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi gilbreen,
Are you running FW 6.4.2 in your system? Try disabling the AFP service under System->Settings and re-enable it afterwards. Rebooting the unit after this procedure would help.
Kind regards,
BrianL
NETGEAR Communit Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Brian,
Yes, I am running FW 6.4.2. I did as you recommended - disabled AFP under System -> Settings, turned it back on, and then rebooted the ReadyNAS. Unfortunately, only the Documents share is available as an AFP share.
Before I reset the ReadyNAS, are there any other suggestions or things I should check?
Thanks.
Gilbert
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Brian,
Thanks for your suggestion. I followed the directions on the linked page, rebooted the NAS, but the share is still not visible via AFP, only SMB.
Not sure what else to try.
Gilbert
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi gilbreen,
Do you have another MAC computer to try? What if you try this procedure (follow the screenshot below)? Just change the SMB to AFP.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have another Mac, and am seeing the same behavior on it. My main machine is running El Capitan and the other machine is still on Yosemite. I thought perhaps it was related to the OS, but it appears that is not the case.
Here are some screen shots of my settings and what happens when I tried to connect via the 'Connect to Server' option.
I am at a loss as to what try next.
Thanks again for your efforts to assist!
Gilbert
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please send in your logs (see the Sending Logs link in my sig)
- Mark as New
- Bookmark
- Subscribe
- Permalink
mdgm,
The logs have been sent in per the linked instructions.
Thanks.
Gilbert
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the logs. Can you send the Config Backup in to the same address? This time please include a link to your post.
- Mark as New
- Bookmark
- Subscribe
- Permalink
mgdm,
Config backup has been emailed along with the link to this post.
Thanks.
GIlbert
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I feel foolish. When I was looking at the settings for the share at Settings -> Network Access, I didn't realize I had to click on the AFP button at the top of the window in order to see the AFP settings. I thought I was looking at global settings for all connection types. Once I clicked on AFP, I saw that the 'Allow anonymous access' was not checked. I checked the box, which prompted the AFP share to disconnect. But once I reestablished the connection, I can see the Media share!
I guess I have a lot to still learn about OS 6 after so many years using OS 4!
Thanks to Brian and mdgm for your assistance.
Gilbert
