- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Accessing NAS via ReadyCLOUD
- Mark as New
- Bookmark
- Subscribe
- Permalink
I wanted to check the current status of my NAS (disk space used, health, etc) which, as far as I know, I can only do over "ReadyCLOUD". This has worked fine in the past, but when I logged in via the web today, it told me I have no registered or shared devices. I have checked that my ReadyCLOUD and MyNetGEAR accounts are linked - they are (I did that some considerable time ago). I have tried using "Discover" in ReadyCLOUD but I just get the spinning symbol. Am I doing something wrong?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Accessing NAS via ReadyCLOUD
No. If you are on the same network as the NAS, you can just browse to https://nas-ip-address/admin or https://nas-name/admin (using the real IP address or hostname of course).
If you aren't on the same network, then you can use a VPN to connect to your home network.
ReadyCloud is totally optional - personally I've chosen not to use it, and I have no problems administering my NAS locally or remotely.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you. That has solved my immediate problem, but I would still like a solution to accessing the NAS remotely.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ReadyCloud can be hit or miss, so one option is to just try later.
Personally I use the OpenVPN service that is built into my Orbi router for remote access. It is free, and apps are available for Android, iOS, Windows, and MacOS. The VPN connects my device to my home network.
Another similar option is to use ZeroTier for remote access - there is an app available for the NAS.
It is also possible to forward a secondary https port in your router to the NAS (combined with using DDNS so you can reach your router w/o knowing it's current IP address). That isn't as secure as the other approaches - if you use it, you need to be careful to use strong passwords on the NAS.
