× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Active Directory permissions not working #25423837
liminal1
Hi guys,
Been going though this with Netgear support but they seem hopeless. Im having permissions issues with my NAS, added it to AD and then set up permissions though windows, but people are still getting locked files. Is Netgear AD intergration really bad, have I picked the wrong company here, what are other peoples experences?
Thanks
Message 1 of 5
mdgm-ntgr
NETGEAR Employee Retired
Re: Active Directory permissions not working
Did you follow this guide when configuring permissions?
I see you have an open support case and support is waiting on you to provide some information.
Message 2 of 5
JennC
Re: Active Directory permissions not working #25423837
Hi liminal1,
You may also try contacting support center to continue with your support case as it seems it is already for escalation, they are already waiting for your response and has been following up since July 15. Click here to see contact number.
We sincerely apologize for any inconvenience this may have caused you.
Message 3 of 5
liminal1
Yes I did follow that guide, but Netgear support makes it very hard when they ask a buch or irelivent questions about a task that I have subbmitted before, they told me it was fixed and its not.
If I may ask can you again provide the following:
1. Logs file I have enabled and given remote support access
2. Config fileI have enabled and given remote support access
3. Admin password I have enabled and given remote support access
4. RAID Type I have enabled and given remote support access
5. Number of drives I have enabled and given remote support access
6. Drive Size  Its a permissions issue
7. Drive Manufacturer Its a permissions issue
8. Drive Model and Serial of each Disk Drive Its a permissions issue
Message 4 of 5
JennC
Hello liminal1,
Those I believe are requirements for escalation. At least give them the system logs and admin password to the NAS, they will be able to get the disk info, RAID config, FW etc from the logs. The admin password is also needed as they will use it to remote access the NAS.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3872 views
  • 0 kudos
  • 3 in conversation
Announcements
