Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Added 3rd drive to Ultra 6...same volume size?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-20
07:53 AM
2012-11-20
07:53 AM
Hi.
I have an Ultra 6 with 2x2TB seagate drives. I purchased a third 2tb drive (identical model to the other two) to increase our storage capacity.
The NAS sees the drive, worked on it for a while.....and still shows the exact same space as before, only with three drives instead of two.
What did I do wrong, and how can I expand the volume? I believe the NAS must have somehow used this disk for dual-redundancy, which I do not want since this NAS acts as a backup for the server on-site. I want to increase the volume size.
Please help.
Thanks!
Please help.
Thanks!
Message 1 of 16
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-20
08:14 AM
2012-11-20
08:14 AM
Re: Added 3rd drive to Ultra 6...same volume size?
Perhaps you did not wait long enough (the size is expanded after the disks are restriped). If you are sure that it is finished, try restarting the NAS.
Message 2 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-20
08:36 AM
2012-11-20
08:36 AM
Well I put it in around 11AM Friday, just rebooted it last night. That's about 72 hours to re-stripe. Isn't that enough? What do I do now?
Message 3 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-20
09:08 AM
2012-11-20
09:08 AM
When I logon to frontview / volumes/volume settings, it shows all three disks, then there's an option that says "next added drive:" and the "Will be used to expand volume" setting is selected. I hit "apply" and....nothing.
I'm looking at frontview on a different Ultra 6, and it doesn't have that option, presumably because I haven't recently added a third drive. The last time I did, I believe it popped up & asked me what I wanted to do; expand the volume or add dual redundancy. I did not get any such option on this NAS.
Any ideas?
Any ideas?
Message 4 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-20
12:58 PM
2012-11-20
12:58 PM
Try restarting it again, if that doesn't work submit an on-line support ticket.
You need 4 drives to get dual redundancy, so any setting you applied there is for the next disk, not the three you have installed.
Message 5 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-20
01:53 PM
2012-11-20
01:53 PM
StephenB wrote: Try restarting it again, if that doesn't work submit an on-line support ticket.
'Should I pull the drive out & re-insert it maybe?
Message 6 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-20
02:30 PM
2012-11-20
02:30 PM
Try the restart first, there are other posts here indicating that multiple restarts are sometimes needed. If you pull/reinsert the drive, Frontview will probably treat it as a new drive.
Does the Frontview "volume settings" page say the volume is redundant? Also, does it show same space allocated (e.g. "xxxx GB allocated" on all three drives?
Message 7 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-20
04:42 PM
2012-11-20
04:42 PM
I restarted like three times, makes no difference whatsoever. Yes frontview says its redundant and exact same space allocated on each drive.
Message 8 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-21
03:03 AM
2012-11-21
03:03 AM
Ok, then. There's some steps in these two links: http://home.bott.ca/webserver/?p=550 and viewtopic.php?f=66&t=42113
If they don't help (or don't apply), then submit an on-line support ticket.
Message 9 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-21
07:49 AM
2012-11-21
07:49 AM
Thank you so much for your help....I will try the steps outlined in those posts & report back soon.
Message 10 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-21
02:43 PM
2012-11-21
02:43 PM
What is the displayed volume size?
What is the displayed size of each disk?
What does your log say about initialisation and resync of the new disk?
If the volume is still around 2tb, then I would suggest that the new disk is probably faulty
Message 11 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-21
04:18 PM
2012-11-21
04:18 PM
vandermerwe wrote: What is the displayed volume size?
Volume C: Online, X-RAID2, 3 disks, 77% of 1846 GB used
Ch 1 : Seagate ST32000542AS [1863 GB]
1858 GB allocated
Ch 2 : Seagate ST32000542AS [1863 GB]
1858 GB allocated
Ch 3 : Seagate ST32000542AS [1863 GB]
1858 GB allocated
LOG:
Fri Nov 16 11:56:19 PST 2012 Volume expansion or migration started. Do not interrupt the system during this time. When finished, email notification will be sent to the alert contact list.
Fri Nov 16 11:55:02 PST 2012 New disk detected. If multiple disks have been added, they will be processed one at a time. Please do not remove any added disk(s) during this time. [Disk 3]
I'd like to admit that I'm on RAIDiator 4.2.19, which is not the latest. I'm afraid to upgrade because we're using Replicate on this NAS & it's working perfectly.
Additionally, I cannot find any setting in Frontview for snapshots - it absolutely does not exist.
Thank you guys for the help.
Message 12 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-21
05:00 PM
2012-11-21
05:00 PM
I have had a similar issue happen on a NAS - the drive I added was not an advanced format drive, and the model number was identical to the other drives which were all advanced format. I replaced the drive with an advanced format drive and all was well.
Message 13 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-22
02:07 PM
2012-11-22
02:07 PM
Have you tried the suggestions in the links StephenB provided?
If you have then either contact support or if you have a current backup you could try hot removing the new disk and replacing it. There is a risk to data though.
Message 14 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-23
10:07 AM
2012-11-23
10:07 AM
corrco wrote: I have had a similar issue happen on a NAS - the drive I added was not an advanced format drive, and the model number was identical to the other drives which were all advanced format. I replaced the drive with an advanced format drive and all was well.
What is an "advanced format" drive? Never heard that term.
All, looks like I will need to open a support ticket as I've tried the steps outlined in those two threads multiple times and still no luck...
Message 15 of 16
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-11-23
11:11 AM
2012-11-23
11:11 AM
http://en.wikipedia.org/wiki/Advanced_Format
All new drives are "Advanced format" - manufacturers agreed to phase out the older format in 2011.
[quote="http://www.seagate.com/tech-insights/advanced-format-4k-sector-hard-drives-master-ti/":u7m21lwc]As all hard drive manufacturers have agreed to transition to the Advanced Format sector design by January 2011, the industry must adapt to and embrace this change to minimize potential negative side effects.[/quote:u7m21lwc]
Message 16 of 16
