× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
BTRFS command not found
OGB
ReadyNAS 102 running 6.10.5 hotfix 1
Trying to stop a volume balance that is at 28% after 20 hrs and causing very slow performance by using command from SSH session:
btrfs cancel volume /data
This returns:
bash : btrfs: command not found
Is this command not in the bash shell? Or not installed?
Would appreciate some insight into getting this command to run...thanks.
Message 1 of 5
Accepted Solutions
Guru
Re: BTRFS command not found
Are you logging in as root (using the NAS admin password)?
Message 2 of 5
All Replies
Guru
Message 2 of 5
Sandshark
Sensei
I suggest you also look for errors on the drives.  Even a volume that's had a lot of changes since the last balance or even been balanced wouldn't normally require that much time.  But disk access errors could cause it to lengthen that much.
Message 3 of 5
Guru
The time to run a balance does depend on the amount of work the filesystem needs to do.  So it can take a very long time,
But I agree that looking for errors is a good idea.  Also, if you aren't certain if you are using SMR drives or not, you might want to research that. SMR drives have very uneven write performance, and that could also be the problem here.
Message 4 of 5
OGB
I was able to figure this out with some help from my dear friend Mr. Google.
Thank you anyway!
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3253 views
  • 1 kudo
  • 3 in conversation
Announcements
