- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Backing up ReadyNAS with RAIDiator 4 to external hard drive connected to Windows 7 Pro PC
- Mark as New
- Bookmark
- Subscribe
- Permalink
When creating a backup job on my ReadyNAS (RN) unit - I am experiencing an error with not being able to connect to my PC running Windows 7 Professional PC.
Here is my setup:
1. Both units are on the same network and connected to the same switch via ethernet cable
2. RN is ReadyNAS Pro Pioneer (RNPP) running RAIDiator 4.2.30
3. Windows PC is named: OPTIMUS7
4. External hard drive is connected to the PC as e: drive
5. I created a test backup folder called: e:\backups-test\
6. Both e: and backups-test are set to Share with Everyone (Read and Write)
7. As a test, I am using RNPP's share named: TTTT
8. I wish to use Rsync protocol
9. IP's of RNPP and PC are 192.168.1.100 and 101, respectively
Here are my RN's backup settings:
When I run the backup, it gets timed out with the follow Prompt:
Error encountered copying data from source path /TTTT/ ==> OPTIMUS7::backups-test due to unknown reason. Please see log. [Job 014]
[Tue Oct 4 19:41:45 PDT 2016]
The following is from the log:
INCREMENTAL Backup started. Tue Oct 4 19:38:35 PDT 2016
Job: 014
Protocol: rsync
Source: [TTTT]/
Destination: OPTIMUS7::backups-test
rsync: failed to connect to OPTIMUS7 (192.168.1.101): Connection timed out (110)
rsync error: error in socket IO (code 10) at clientserver.c(122) [sender=3.0.9]
Backup failed. Tue Oct 4 19:41:45 PDT 2016.
Reason for failure:
I have tried the following:
1) changed the Host: and Path: names several ways. Two (of many) examples are:
\\OPTIMUS e/backups-test
OPTIMUS //e/backups-test
etc...
2) Using another device connected to the same network, I am able to see all the contents of the share: backups-test
3) Clicking the Test Connection button from the backup settings page, and it times out after a while
4) Turned off Windows Firewall for the Home or Private Network then Clicking the Test Connection button from the backup settings page immediately gives the following Prompt:
Error connecting to OPTIMUS7
And the log says:
INCREMENTAL Backup started. Tue Oct 4 19:59:28 PDT 2016
Job: 014
Protocol: rsync
Source: [TTTT]/
rsync: failed to connect to OPTIMUS7 (192.168.1.101): Connection refused (111)
Backup failed. Tue Oct 4 19:59:28 PDT 2016.
Reason for failure:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Backing up ReadyNAS with RAIDiator 4 to external hard drive connected to Windows 7 Pro PC
If you want to use Rsync you need to be running Rsync on the PC.
One option is to get DeltaCopy and to replace Rsync and other Linux binaries in the Deltacopy folder with the latest ones from Cygwin.
Useful links: Sending Logs|My ReadyNAS Gear|FAQ|Hardware Compatibility List|Docs: Setup Guide, Manual|Downloads|Unofficial Tips|GPL|MDGM on Twitter|MDGM's Unofficial Guides
NB: A ReadyNas is not an excuse not to have a backup. Fire, theft, multiple disk failures, other hardware failure, floods, user negligence etc. can all result in loss of data.
How to contact NETGEAR Technical Support | Australia: 1300 361 254 / Other Numbers|Online Submission
Unofficial Guide for Moving from Sparc ReadyNAS to x86 ReadyNAS|Using Gmail with the ReadyNAS|XRAID Volume Size Calculator
