× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Backup between readynas's on different networks - possible? How?
mrdano-nas
Hello All,
I have two Netgear ReadyNas'
I want to setup a daily backup that puts a copy of my work Nas on my home Nas every night - for security and peace of mind.
My two Nas drives are as follows;
Work= ReadyNas Duo - 1tb - running OS 4.1.16
Home = ReadyNas Pro 6 - 3tb - running OS 6.9.5 (legacy model upgraded and working perfectly)
Is this possible to setup and how would it be done? Are there any requirements to make it happen?
Thank you
Message 1 of 7
Marc_V
NETGEAR Employee Retired
Re: Backup between readynas's on different networks - possible? How?
Hi @mrdano-nas
Welcome to the Community!
Rsync backup is one way to do what you want. You can push or pull the data from your NAS. You will have to setup forwarding on your routers to allow connection of both NAS.
Here are guides for both OS 4 and OS 6 Rsync backup.
OS 4 Rsync
OS 6 Rsync
Rsync over SSH
Hope this helps!
Regards
Message 2 of 7
mrdano-nas
Thank you - do you mean 'port forwarding' on the routers?
Message 3 of 7
Marc_V
Yes, Standard port for RSYNC is Port 873 and RSYNC over SSH uses Port 22.
You can also setup a VPN connection instead if your routers support it.
Message 4 of 7
mrdano-nas
Would i need to have a static IP at each router / network to make this work?
I need to check if they are static or not.
Message 5 of 7
Marc_V
It would be best if you have Static IP @mrdano-nas 🙂
Message 6 of 7
Guru
While the two routers can have static IP addresses, the other option is to set up ddns.   That would allow you to use a name for the backup destinations instead of an IP address - somethind like mrdano.ddns.net.  There are some free DDNS services out there (noip.com for instance), but static IP addresses will cost you, and aren't really needed.
Some routers (Netgear Nighthawks for example) have DDNS built in, but you can also run a client on a PC.  Either way you will be able to use it to reach the NAS.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1025 views
  • 0 kudos
  • 3 in conversation
Announcements
