Orbi WiFi 7 RBE973
Reply
Backup via FTP Not working - please help
PegWeb
I am trying to backup via FTP. When I do the test connection everything says it connects fine. When i actually try to run the backup job though it doesn't work. I can see it login to the server just fine but then it just sits there and doesn't do anything. Not sure what to try next.
Here are the logs from the Ready NAS 1100
INCREMENTAL Backup started. Sun Jan 5 22:32:05 EST 2014
Job: 002
Protocol: ftp
Source: ftp://mail.pegweb.com/
Destination: [Mail-Server]/
http://0/:
2014-01-05 22:32:05 ERROR 400: Bad Request.
And here is the log of the same connection from the FileZilla server.
Logged on
(000004)1/5/2014 22:37:08 PM - (not logged in) (174.97.46.38)> Connected, sending welcome message...
(000004)1/5/2014 22:37:08 PM - (not logged in) (174.97.46.38)> 220-FileZilla Server version 0.9.43 beta
(000004)1/5/2014 22:37:08 PM - (not logged in) (174.97.46.38)> 220-written by Tim Kosse (Tim.Kosse@gmx.de)
(000004)1/5/2014 22:37:08 PM - (not logged in) (174.97.46.38)> 220 Please visit http://sourceforge.net/projects/filezilla/
(000004)1/5/2014 22:37:08 PM - (not logged in) (174.97.46.38)> USER mailbackup
(000004)1/5/2014 22:37:08 PM - (not logged in) (174.97.46.38)> 331 Password required for mailbackup
(000004)1/5/2014 22:37:08 PM - (not logged in) (174.97.46.38)> PASS **********
(000004)1/5/2014 22:37:08 PM - mailbackup (174.97.46.38)> 230 Logged on
(000004)1/5/2014 22:37:08 PM - mailbackup (174.97.46.38)> SYST
(000004)1/5/2014 22:37:08 PM - mailbackup (174.97.46.38)> 215 UNIX emulated by FileZilla
(000004)1/5/2014 22:37:08 PM - mailbackup (174.97.46.38)> PWD
(000004)1/5/2014 22:37:08 PM - mailbackup (174.97.46.38)> 257 "/" is current directory.
(000004)1/5/2014 22:37:08 PM - mailbackup (174.97.46.38)> TYPE I
(000004)1/5/2014 22:37:08 PM - mailbackup (174.97.46.38)> 200 Type set to I
(000004)1/5/2014 22:37:08 PM - mailbackup (174.97.46.38)> PASV
(000004)1/5/2014 22:37:08 PM - mailbackup (174.97.46.38)> 227 Entering Passive Mode (209,9,227,90,193,209)
(000004)1/5/2014 22:39:08 PM - mailbackup (174.97.46.38)> 421 Connection timed out.
(000004)1/5/2014 22:39:08 PM - mailbackup (174.97.46.38)> disconnected.
Message 1 of 5
tuxmike
Re: Backup via FTP Not working - please help
http://0/:
Seems like you did not specify some host adress, so it is filled with "0".
Best, tuxmike
Message 2 of 5
PegWeb
Here is the source as I have it filled out. I just blurred out the credentials. When i click Test Connection it works fine.
Then this is what I have the destination set to which is just a share on the NAS.
Message 3 of 5
Guru
IF you connect to the FTP site with the filezilla client using the same credentials, does that work properly?
The first post shows a connection timeout with FileZilla, so you probably also need to confirm that data transfers from the server to the PC work as expected.
Message 4 of 5
PegWeb
Yes. Even when the ReadyNAS connects I can see it connect just fine. It just doesn't seem to do anything once it connects then it times out. The snippet from both logs is in my original post.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2967 views
  • 0 kudos
  • 3 in conversation
Announcements
