marius_roma
Jul 09, 2012Aspirant
Best practice for a VMware vSphere datastore
I need to create a share and to use it as a datastore for a VMware ESXi 5.0 server member of a VMware vSphere 5 infrastructure.
Is there any documentation with the best practice to configure the share?
marius
- Shoud I use NFS or iSCSI?
How should I set the permission?
Is there any additional hint?
marius
- SlaskyAspirantI've got a setup at my workplace with an Ubuntu machine sharing a NFS store which I connect to from my ESXi machine.
These machines are connected with a 1GB ethernet line, through a switch but it works fine. I havent seen any read issues and the speed seems like it should be at the RAID 5 config I got on the share-machine.
I haven't tried checking performance with iSCSI, but it might be worth a shot.
The easiest way to set it up is by NFS I guess (as stated, havent tried iSCSI)
What kind of NAS do you have? - marius_romaAspirantI apologize for missing a critical information.
The NAS is a NetGear ReadyNAS 3100 NAS.
It will be used to host either as a VMware datastore and a CIFS share used by Veeam backup.
Regards
marius - SlaskyAspirantAs stated above, I havent had any performance problems on my setup, although I only have 2 VM's on that datastore though.
The X-RAID will probably give you the performance you need. What kind of machines are we talking about? Is it heavy on the read/write or only print services or domain servers?
And I guess the veeam is running at night?
How many disks are you using at the moment? - SlaskyAspirantAnd from what I can read, if you define the share as iSCSI you can define the sharesize. With NFS you use the entire volume, no matter what, and how many shares you have.
- gavindAspirant
Slasky wrote: I've got a setup at my workplace with an Ubuntu machine sharing a NFS store which I connect to from my ESXi machine.
Centos is also good in NFS store. We're currently using this and so far, everything runs smooth. - Commander_CodyAspirantIf you're going to be running intensive application's I think RAID-10 would be better then x-raid2 (5)
Write performance would be faster, though capacity would of course be lower.Commander_Cody wrote: If you're going to be running intensive application's I think RAID-10 would be better then x-raid2 (5) - chirpaLuminaryNot sure if there is a newer revision of this doc, its two years old, but may be a good starting point:
Application_Notes-ReadyNAS_iSCSI_as_VMWare_Datastore-v1.pdf
- Nov 12, 2018Retired_Member
