× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Browser not accessing ReadyNAS GUIs
Tiltsinoz
Hi there, hoping someone has a solution to a fairly major issue accessing the U.I.s of my two old (but still going strong) ReadyNAS Duos. Since my Edge Browser has updated it refuses to access the IP address of either of my units. Downloaded Chrome to try that instead but no good either. Had a bit of a look around the Community for any other clues without luck. Any advice much appreciated!
Model: RND2000|ReadyNAS Duo Chassis only, RND2000v2|ReadyNAS Duo v2 Chassis only
Message 1 of 3
Tiltsinoz
Re: Browser not accessing ReadyNAS GUIs
Whoa, worked it out - Edge has an Internet Explorer mode so I can use that to access Frontview!
Message 2 of 3
Guru
Great.
Double-check that you are running the most recent firmware:
  • 4.1.16 for the original sparc-based duo (likely what you have, since you reference frontview).
  • 5.3.13 for the v2
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 930 views
  • 0 kudos
  • 2 in conversation
Announcements
