× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Call to undefined function curl_init() on 6.10.0
GJSchaller
Guide
I recently installed Nextcloud on my ReadyNAS, which is running 6.10.0.  The installer package installs Nextcloud 13.0.5, which is an older version.  When I run the updater from the command line, I get an error as follows:
root@GeoffNAS:~# sudo -u admin php /apps/nextcloud/web/updater/updater.phar
Nextcloud Updater - version: v13.0.5RC1
Current version is 13.0.5.
PHP Fatal error: Uncaught Error: Call to undefined function NC\Updater\curl_init() in phar:///apps/nextcloud/web/updater/updater.phar/lib/Updater.php:423
How can I enable curl_init on the embedded version of PHP, or is there another way of updating Nextcloud?
The Web-Based installer also fails (without error - presumably the same issue).  I've verified php5-curl is installed, and added the line
extension=curl.so
To /etc/php5/web and /etc/php5/cli
Any ideas how to get the updater to run?
Model: RN21400|ReadyNAS 214 Series 4- Bay (Diskless)
Message 1 of 3
Guru
Re: Call to undefined function curl_init() on 6.10.0
There is a huge issue with php and 6.10.0. I suggest waiting for @WhoCares_ to resolve it.  Then perhaps purchase the fixed app from http://rnxtras.com
He gives a brief explanation of the issue there.
Message 2 of 3
GJSchaller
Guide
I'm aware, and have been monitoring, but would like to patch up my Nextcloud while I can rather than leave an upatched system facing the internet.
If we can get curl_init working, the update will be simple.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 830 views
  • 0 kudos
  • 2 in conversation
Announcements
