Orbi WiFi 7 RBE973
Reply
Can't access shares that I have permissions for
kelstrup
Hello
I have set a password for the admin account, and I know I got it right, cause I can open the files from http, and I can manage the NAS in the web admin system.
But I am unable to access all those shares that have permissions set, including the admin share. How can I override the access restrictions?
Using RaidAR 4.3.8.
Thanks
Model: ReadyNASRND2110|ReadyNAS Duo
Message 1 of 8
Accepted Solutions
kelstrup
Re: Can't access shares that I have permissions for
Thnx, stopping the credential manager service did the trick 🙂
Message 7 of 8
All Replies
aks
Virtuoso
Virtuoso
In what way are you trying to access the shares, which OS, and which account are you using to log in to the Duo when you are trying this?
Perhaps you are using Windows (7/8/10?) and using Windows Explorer? Or maybe you are using a Mac?
Message 2 of 8
kelstrup
Hey, thanks for replying. Am on Windows 10, trying to navigate using Windows Explorer. Can see the files through http, as e.g. in Microsoft Explorer.
Is FTP an option perhaps? A simple ftp to the ip address says Connection refused.
I'm not sure I quite understand this part, though: "which account are you using to log in to the Duo when you are trying this?"
Message 3 of 8
Guru
Yes, it is an option.  Can you let us know what NAS firmware you are running?  It should be either 4.1.x or 5.3.x.
Well, you are setting up restricted folders, so you need to ensure that the PC is using the correct credentials when accessing the NAS.  These credentials are the accounts (user+password) you have set up on the NAS.
If you don't specify credentials, then Windows will first look in its credential manager - if the nasname is saved there, then it will use the associated credential.  If it isn't saved there, then Windows will present the PC login credentials to the duo.  If that user/password fails, access is rejected - even if the share has guest access enabled.
Windows also only allows one credential at a time.  So if you access \\nasname\admin using admin credentials, you can't  simultaneously access \\nasname\sharename using some other credentials.  There is a trick though - if you access \\nasipaddress\admin using admin credentials, you can access \\nasname\sharename using other credentials - Windows treats the IP address as a different machine.
This can get complicated, so perhaps you might want to tell us what you want to accomplish (e.g., what users you have, and how you want to restrict there access).
Message 4 of 8
aks
Virtuoso
Virtuoso
You can (should) use Windows Explorer, it works fine usually.
When you browse to the NAS, \\{nas}\share, Windows would have asked for credentials. If you did not enter a NAS user, then it would try guest, which would have limited access. Perhaps this happened?
Open Windows Credentials Manager and remove the NAS entry. Add a new entry for the NAS, using NAS credentials (username and password - admin should work fine).
Message 5 of 8
aks
Virtuoso
Virtuoso
Posts crossed again 🙂
Message 6 of 8
kelstrup
Message 7 of 8
kelstrup
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 3198 views
  • 0 kudos
  • 3 in conversation
Announcements
