Orbi WiFi 7 RBE973
Reply
Can't change TM Capacity on Ultra 2
gemereno
Hi,
I initially set capacity to 100GB. I launched TM and it comes back saying 100GB is not enough. It requires 200GB.
I went back to FV and changed to 300GB and Applied. Refreshed. All looks ok. Relaunched TM and...got the same message. I tried to disable TM altogether in FV and then, TM says there is no disk to backup to. Then re-enabled TM on FV with 300GB, started TM and got the initial message (100GB) again.
It seems Ultra 2 will not change the size of the TM capacity on the volume. A precision: the volume is set as FLEX and not as XRAID2.
Please advise,
Thanks
Olivier
Message 1 of 3
mdgm-ntgr
NETGEAR Employee Retired
Re: Can't change TM Capacity on Ultra 2
What version of RAIDiator are you running? How much free space is on Volume C? Have you tried rebooting (via System > Shutdown) doing a "quota check" only (do not do a filesystem/volume check)?
What version of Mac OS X? Have you tried rebooting your Mac?
Message 2 of 3
gemereno
RAIDiator 4.2.22; OSX 10.7.5;
C has just been reformatted to become FLEX. So 2TB less 40GB.
I need to reboot NAS but can't do it now cause restoring files from backup of XRAID volume.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2928 views
  • 0 kudos
  • 2 in conversation
Announcements
